Demo Source Code
The Python source code of this demo is provided for reference purpose only.
I2C_Sense_Hat.py:
#!/usr/bin/python ''' Please make sure the sense HAT(B) is connected to the correct pins. The following table describes how to connect the Sense HAT(B) to the 40-pin header. -------------------------------------------- __Sense HAT (B)___Pin Number_____Pin Name 3V3 1 3.3 V Power GND 9 GND SDA 3 I2C SDA SCL 5 I2C SCL -------------------------------------------- ''' import sys import struct import fcntl import os import math import time import VisionFive.i2c as I2C import VisionFive.boardtype as board_t SHTC3_I2C_ADDRESS = 0x70 I2C_SLAVE = 0x0703 #I2C_DEVICE = "/dev/i2c-1" #I2C_DEVICE = "/dev/i2c-0" ##Commands cmd_dict = { "SHTC3_WakeUp": 0x3517, "SHTC3_Sleep": 0xB098, "SHTC3_NM_CE_ReadTH": 0x7CA2, "SHTC3_NM_CE_ReadRH": 0x5C24, "SHTC3_NM_CD_ReadTH": 0x7866, "SHTC3_NM_CD_ReadRH": 0x58E0, "SHTC3_LM_CE_ReadTH": 0x6458, "SHTC3_LM_CE_ReadRH": 0x44DE, "SHTC3_LM_CD_ReadTH": 0x609C, "SHTC3_LM_CD_ReadRH": 0x401A, "SHTC3_Software_RES": 0x401A, "SHTC3_ID": 0xEFC8, "CRC_POLYNOMIAL": 0x131, } def SHTC3_CheckCrc(data, len, checksum): crc = 0xff for byteCtr in range(0, len): crc ^= data[byteCtr] for bit in range(8, 0, -1): if(crc & 0x80): crc = (crc << 1) ^ cmd_dict["CRC_POLYNOMIAL"] else: crc = crc << 1 if (crc != checksum): return 1 else: return 0 def SHTC3_WriteCommand(cmd): buf0 = (cmd >> 8)& 0xff buf1 = cmd & 0xff buf = [buf0, buf1] I2C.write(buf) def SHTC3_WAKEUP(): SHTC3_WriteCommand(cmd_dict["SHTC3_WakeUp"]) time.sleep(0.03) def SHTC3_SLEEP(): SHTC3_WriteCommand(cmd_dict["SHTC3_Sleep"]) def SHTC_SOFT_RESET(): SHTC3_WriteCommand(cmd_dict["SHTC3_Software_RES"]) time.sleep(0.03) def getdata(): time.sleep(0.02) buf_list = I2C.read(3) checksum = buf_list[2] DATA = 0 if (not SHTC3_CheckCrc(buf_list, 2, checksum)): DATA = (buf_list[0] << 8 | buf_list[1]) return DATA def SHTC3_Read_DATA(): SHTC3_WriteCommand(cmd_dict["SHTC3_NM_CD_ReadTH"]) TH_DATA = getdata() SHTC3_WriteCommand(cmd_dict["SHTC3_NM_CD_ReadRH"]) RH_DATA = getdata() TH_DATA = 175 * TH_DATA /65536.0 -45.0 #Calculate the temperature value. RH_DATA = 100 * RH_DATA / 65536.0 #Calculate the humidity value. DATA = [TH_DATA,RH_DATA] return DATA def getTem(): SHTC3_WriteCommand(cmd_dict["SHTC3_NM_CD_ReadTH"]) TH_DATA = getdata() TH_DATA = 175 * TH_DATA /65536.0 -45.0 #Calculate the temperature value. return TH_DATA def getHum(): SHTC3_WriteCommand(cmd_dict["SHTC3_NM_CD_ReadRH"]) RH_DATA = getdata() RH_DATA = 100 * RH_DATA / 65536.0 #Calculate the humidity value. return RH_DATA def main(): #Determining cpu Type: 1 means visionfive1; 2 means visionfive 2 vf_t = board_t.boardtype() if vf_t == 1: I2C_DEVICE = "/dev/i2c-1" elif vf_t == 2: I2C_DEVICE = "/dev/i2c-0" else: print('This module can only be run on a VisionFive board!') return 0 #Open the Sense HAT by I2C. ret = I2C.open(I2C_DEVICE, SHTC3_I2C_ADDRESS) if (ret < 0): return 0 SHTC_SOFT_RESET() i = 0 while i < 7: Temp = getTem() Hum = getHum() SHTC3_SLEEP() SHTC3_WAKEUP() print("Temperature = {:.2f}°C , Humidity = {:.2f} %\n".format(Temp, Hum)) i = i + 1 I2C.close() return 0 if __name__ == "__main__": sys.exit(main())
