Switch to the code branch by executing the following commands:
cd linux
git checkout -b JH7110_VisionFive2_devel origin/JH7110_VisionFive2_devel
git pull
Type the following to set the default configuration settings for compiling Linux
Kernel.
make <Configuration_File> CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv
Tip:<Configuration_File>: For VisionFive 2, the file is
starfive_visionfive2_defconfig.
Type the following to set additional configuration settings for compiling Linux Kernel.
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv menuconfig
Compile the Linux Kernel.
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv -jx
Note: Here you need to change the -jx value
according to the number of cores in your CPU. If your CPU has 8 cores, change this to
-j8. This process will take some time and therefore please wait
patiently.
The kernel image will be generated inside the directory
linux/arch/riscv/boot as
Image.gz.Figure 1. Example Output The dtb files will be generated inside the directory
linux/arch/riscv/boot/dts/starfiveFigure 2. Generated dtb Files The Image.gz and .dtb files will be
used later in this guide when we try to move rootfs, dtb and kernel to VisionFive 2.
Different boards use different dtb files:
jh7110-visionfive-v2.dtb: for Version 1.2A and 1.3B board.
jh7110-visionfive-v2-ac108.dtb: for version 1.2A and 1.3B board with ac108 codec.
jh7110-visionfive-wm8960.dtb: for Version 1.2A and 1.3B board with wm8960 codec.
Tip: You can refer to the silk print on the board for version information.
