Kernel Menu Configuration
Follow the steps below to enable the kernel configuration for GPIO.
    make linux-menuconfig
    Figure 1. Device Drivers
  3. Enter the Pin controllers menu.
    Figure 2. Pin Controllers
  4. Select the Pinctrl driver for StarFive SoC option to enable the pinctrl driver, and select the Pinctrl and GPIO driver for StarFive JH7110 SoC option to enable the GPIO driver respectively.
    Figure 3. Driver Menu
  5. Save your change before you exit the kernel configuration dialog.
