Test Example
For HDMI Output
The following command shows an example for testing the HDMI output.
modetest -M starfive -D 0 -a -s 116@31:1920x1080 -P 39@31:1920x1080@RG16 -Ftiles
The following list provides explanations for the parameters in the above example command.
  • 116@31:1920x1080 - <Connector ID>@<CRTC ID>: <Resolution>
  • 39@31:1920x1080@RG16 - <Plane ID>@<CRTC ID>: <Resolution>@<Format>
Output Result
The following photo shows the output generated from the above example command.
Figure 1. Test Example
