Kernel Menu Configuration
Follow the steps below to enable the kernel configuration for I2C.
- Under the root directory of
freelight-u-sdk, type the following command to
enter the kernel menu configuration GUI.
make linux-menuconfig - Enter the Device Drivers menu.
Figure 1. Device Drivers
- Enter the I2C support menu.
Figure 2. I2C Support
- Enter the I2C Hardware Bus Support menu.
Figure 3. I2C Hardware Bus Support
- Select the Synopsys DesignWare Platform option.
Figure 4. Synopsys DesignWare Platform
- Save your change before you exit the kernel configuration dialog.
