Source Code Structure
The source code structure of I2C is listed in the following code blocks.
The following code block displays the source code structure for the I2C Subsystem layer.
├── drivers
│   ├── i2c
│   │   ├── i2c-core.h
│   │   ├── i2c-boardinfo.c
│   │   ├── i2c-core-of.c
│   │   ├── i2c-core-slave.c
│   │   ├── i2c-mux.c
│   │   ├── i2c-core-acpi.c
│   │   ├── i2c-core-smbus.c
│   │   ├── i2c-smbus.c
│   │   ├── i2c-core-base.c
│   │   └── i2c-dev.c
The following code block displays the source code structure for the Synopsys DesignWare I2C adapter driver.
linux-5.15.0
├── drivers
│   ├── i2c
│   │   ├── busses
│   │   │   ├── i2c-designware-core.h
│   │   │   ├── i2c-designware-common.c
│   │   │   ├── i2c-designware-master.c
│   │   │   ├── i2c-designware-slave.c
│   │   │   ├── i2c-designware-pcidrv.c
│   │   │   ├── i2c-designware-baytrail.c
│   │   │   └── i2c-designware-platdrv.c
