File Structure
The following diagram shows the file structure of the StarFive ISP SDK.
  • The file libCI_User.a contains the IOCTL objects.
  • The file libISPC.a contains the device, control, module, and pipeline objects.
  • The file libSensorapi.a is the sensor library.
  • The application stf_isp_ctrl is the ISP control application.
Figure 1. File Structure
