Reset
Reset the sensor.
Reset(
    SENSOR_HANDLE *pstHandle
The function has the following parameter.
Table 1. Reset Parameter Description
pstHandle Sensor handle Input
Table 2. Reset Return Description
Return Description
0 Success
Other values Failure
None
