Sensor_Create
Sensor structure create and initialization.
Sensor_Create(
    SENSOR_HANDLE **ppstHandle,
    STF_U8 u8Index
Table 1. Sensor_Create Parameter Description
ppstHandle Sensor handle Input/Output
u8Index Sensor setting index. No longer in use Input
Table 2. Sensor_Create Return Description
Return Description
0 Success
Other values Failure
None
