Audio Playing
The topic provides examples for playing an audio file.
The following code block shows the example in different scenarios.
- Play an audio file with PWMDAC:
Required devices: JH7110 EVB or VisionFive 2
ffmpeg -i test1-32k-16b.wav -f alsa -acodec pcm_s16le hw:0,1
- Play an audio with wm8960:
Required devices: JH7110 EVB + wm8960 audio board or VisionFive 2 + wm8960 audio board
ffmpeg -i test1-16k-32b.wav -f alsa -acodec pcm_s32le hw:0,1
