Block Diagram
The following figure shows the block diagram of the OpenMAX module.
Figure 1. OpenMax Block Diagram
JH7110 SDK use OpenMAX IL layer only.
  • OpenMAX IL: Integration Layer
OpenMAX IL serves as a low-level interface for audio, video, and imaging codecs used in embedded and/or mobile devices. It gives applications and media frameworks the ability to interface with multimedia codecs and supporting components (i.e., sources and sinks) in a unified manner. The codecs themselves may be any combination of hardware or software and are completely transparent to the user. Without a standardized interface of this nature, codec vendors must write to proprietary or closed interfaces to integrate into mobile devices. The principal goal of the IL is to give codecs a degree of system abstraction using a specialized arsenal of features, honed to combat the problem of portability among many vastly different media systems.
