Sysfs Interface Example
In the user space, you can easily control PWM through sysfs interface supported by Linux.
The following procedure provides an example for it.
Enter the following directory, you can see all the registered PWM chips.
# cd /sys/class/pwm/ # ls pwmchip0 -
Enter the directory pwmchip*, run command
echo X > export.Note: In the command, the parameter X is the PWM channel which you want to control.Result: Then the directory pwmX is generated.# cd pwmchip0/ # ls device export npwm power subsystem uevent unex-port # echo 0 > export # ls device npwm pwm0 uevent export power subsystem unexport # echo 1 > export # ls device npwm pwm0 subsystem unexport export power pwm1 uevent -
Enter the directory pwmX, you can see all states of this PWM channel.
The following list provides descriptions for the parameters.- enable: Enable or disable the PWM channel. 1 for enable, 0 for disable.
- polarity: Invert polarity or not. 1 for invert polarity, 0 for normal (do not invert).
- period: Enter the period of PWM signal (unit: ns)
- duty_cycle: Enter the duty cycle of PWM signal (unit: ns)
Now, you can change the states of PWM channel using commands of echo and cat.
# cd pwm0/ # ls capture enable polarity uevent duty_cycle period power # echo 10000 > period # echo 5000 > duty_cycle # cat period 10000 # cat duty_cycle 5000 # cat polarity normal # cat enable 1
