Proc Interface
The proc interface is only used to read the RTC status.
You can run the following command to execute the read process:
cat /proc/driver/rtc
The following code block shows an example of using the interface.
# cat /proc/driver/rtc
rtc time         : 00:06:19
rtc date         : 2001-02-01
alrm_time        : 00:00:10
alrm_date        : 2001-02-01
alarm_IRQ        : no
alrm_pending     : no
update IRQ enabled     : no
periodic IRQ enabled   : no
periodic IRQ frequency : 1
max user IRQ frequency : 64
24hr             : yes
