rtc_set_offset
  • Syntax:
    int rtc_set_offset(struct rtc_device *rtc, long offset)
  • Description: The function is used to adjust the duration of the average second.
  • Parameter:
    • rtc: The target RTC device.
    • offset: The offset in parts per billion.
  • Return:
    • Success: 0.
    • Failure: Error code.
