Introduction
The thermal system uses a thermal sensor to load the current temperature of the CPU and GPU. Then, based on the value, you can adjust the working frequency of the GPU and CPU, for example, control the maximum frequency. In the end, thermal control can avoid over-high temperatures for the entire JH7110 SoC platform.
