USB Overcurrent Debug
USB overcurrent indicates that the current limit of the USB port has been exceeded.
Many electronic devices have a rated current, once the current has been exceeded the device may be burned out. So these devices are equipped with current protection modules. When it exceeds the set current, the device powers off automatically to protect the device, which is called overcurrent protection.
For example, if the USB port of the development board is used to power the device and there is a high current surge, the development board will protect the USB port itself, causing the USB port to be unavailable.
On JH7110, the USB host has an OC signal to detect the USB signal. If the signal is not connected, JH7110 will judge that the USB port is in an overcurrent state, causing it to be unusable.
The following is the workaround to avoid this problem:
  1. Enable USB host mode by configuring the node of the USB controller in the DTS file of the kernel, and remove overcurrent pinctrl. The following is an example:
    The original node:
    usb_pins: usb-pins {
    	drive-vbus-pin {
    			starfive,pins = <PAD_GPIO33>;
    			starfive,pinmux = <PAD_GPIO33_FUNC_SEL 0>;
    			starfive,pin-ioconfig = <IO(GPIO_IE(1))>;
    			starfive,pin-gpio-dout = <GPO_HIGH>;
    			starfive,pin-gpio-doen = <OEN_LOW>;
    	overcurrent-pin {
    			starfive,pins = <PAD_GPIO34>;
    			starfive,pinmux = <PAD_GPIO34_FUNC_SEL 0>;
    			starfive,pin-gpio-din = <GPI_USB0_OVERCURRENT_N_IO>;
    			starfive,pin-gpio-doen = <OEN_HIGH>;
    &usbdrd30 {
    	pinctrl-names = "default";
    	dr_mode = "host"; /*host or peripheral*/
    	status = "disabled";
    Modified node:
    	drive-vbus-pin {
    &usbdrd30 {
    	status = "okay";
  2. Set up USB overcurrent signal by configuring sys iomux register.
    value = readl(priv->base + JH7110_SYS_GPI); // priv->base:0x13040000; JH7110_SYS_GPI: 0x80
    value &= ~(0x7f << 16);
    value |= BIT(16);
    writel(value, priv->base + JH7110_SYS_GPI);
    Note: To avoid timing issues, please modify the above settings during the U-Boot phase.
