PING - Digital Loopback
After you have confirmed the access to the PHY is ready, you can use the PING command to initiate a digital loopback for send and receive ping data packages.
To initiate the test, run the command ping $ipaddr.
The following figure shows an example return of executing the command.
Figure 1. Ping Command
