Functional Introduction
The AT8563 supports the following features and specifications on
the Real Time Clock (RTC) module.
- Wide working voltage range: 1.0 V to 5.5 V
- The typical value of low sleep current is 0.25 μ A (VDD = 3.0 V, Tamb = 25 ℃)
- With a century symbol, it can work from year 1900 to 2099 (years are related to the century, mainly used to calculate the number of days in February during leap years)
- I2C bus interface supports the frequency up to 400k Hz (VDD = 1.8 V to 5.5V); Read address is 0A3H and write address is 0A2H
- Programmable clock output frequency is 2.768k Hz/1024 Hz/32 Hz/1 Hz
- Contains alarms and timers
- Supports low voltage detection function and power-on reset failure function
- Open drain interrupt output pin
