ioctl Interface
The
ioctl interface can be used to: - Obtain an RTC device handle
- Configure RTC time
The following demo program provides an example of using the interface.
1 #include <stdio.h> 2 #include <stdlib.h> 3 #include <unistd.h> 4 #include <sys/types.h> 5 #include <sys/stat.h> 6 #include <fcntl.h> 7 #include <linux/rtc.h> /* Where the RTC ioctl commands is stored */ 8 #include <errno.h> 9 #include <string.h> 10 11 #define RTC_DEVICE_NAME "/dev/rtc0" /* The device name of the RTC device */ 12 13 /* Set RTC time */ 14 int set_rtc_time(int fd) 15 { 16 struct rtc_time rtc_tm; 17 18 rtc_tm.tm_year = 2022 - 1900; /* year, range: 101-199, which matches 2001-2099 */ 19 rtc_tm.tm_mon = 7 - 1; /* month, range: 0-11, which matches 1-12 */ 20 rtc_tm.tm_mday = 15; /* day */ 21 rtc_tm.tm_hour = 14; /* hour */ 22 rtc_tm.tm_min = 10; /* minute */ 23 rtc_tm.tm_sec = 20; /* second */ 24 25 if (ioctl(fd, RTC_SET_TIME, &rtc_tm) < 0) { 26 printf("RTC set time failed\n"); 27 return -1; 28 } 29 30 return 0; 31 } 32 33 /* Read RTC time */ 34 int read_rtc_time(int fd) 35 { 36 struct rtc_time rtc_tm; 37 38 if (ioctl(fd, RTC_RD_TIME, &rtc_tm) < 0) { 39 printf("RTC read time failed\n"); 40 return -1; 41 } 42 printf("RTC time: %04d-%02d-%02d %02d:%02d:%02d\n", 43 rtc_tm_temp.tm_year + 1900, rtc_tm_temp.tm_mon + 1, rtc_tm_temp.tm_mday, 44 rtc_tm_temp.tm_hour, rtc_tm_temp.tm_min, rtc_tm_temp.tm_sec); 45 46 return 0; 47 } 48 49 int main(int argc, char *argv[]) 50 { 51 int fd, ret; 52 53 /* Open RTC device */ 54 fd = open(RTC_DEVICE_NAME, O_RDWR); 55 if (fd < 0) { 56 printf("Open rtc device %s failed\n", RTC_DEVICE_NAME); 57 return -ENODEV; 58 } 59 60 /* Set time */ 61 ret = set_rtc_time(fd); 62 if (ret < 0) 63 return -EINVAL; 64 65 /* Read time */ 66 ret = read_rtc_time(fd); 67 if (ret < 0) 68 return -EINVAL; 69 70 close(fd); 71 return 0; 72 }
