This document mainly describes how to compile firmware, u-boot, Linux Kernel and make file systems.
| V1.0 | 2021-12-08 | The first official release. |
| V1.1 | 2022-02-17 | Updated the command in step 12 in the Method 1: Using Micro-SD Card section. |
