Running Demo Code
To run the demo code, perform the following on VisionFive 2 Debian:
  1. Locate to the directory where the test code, pwm_led.py, exists:
    1. Execute the following command to get the directory where VisionFive.gpio exists:
      pip show VisionFive.gpio
      Example Result:
      Note:
    2. Execute the following to enter the directory, for example, /usr/local/lib64/python3.9/site-packages as indicated in the previous step output:
      cd /usr/local/lib64/python3.9/site-packages
    3. Execute the following command to enter the sample-code directory:
      cd ./VisionFive/sample-code/
  2. Under the sample-code directory, execute the following command to execute the demo code:
    sudo python pwm_led.py
    sudo python3 pwm_led.py
    The LED blinks and the blink frequency will change according to the PWM frequency.
