Running Demo Codes
  1. Locate to the directory where the test code, basic_edge_detection.py, exists:
    1. Source into the Python3 Virtual Environment:
      source ./myvenv/bin/activate
    2. Execute the following command to install dependency:
      python3 -m pip install pillow
    3. Execute the following command to get the directory where VisionFive.gpio exists:
      Note:
    4. Execute the following to enter the directory, for example, /home/user/myvenv/lib/python3.11/site-packages as indicated in the previous step output:
    5. Execute the following command to enter the sample-code directory:
      cd ./VisionFive/sample-code/
  2. Under the sample-code directory, execute the following command to execute the demo code:
    sudo python basic_edge_detection.py
    sudo python3 basic_edge_detection.py
    • The terminal displays as follows:
      # python3 basic_edge_detection.py
      *-----------------------Case 1-------------------------*
      Please press the key on pin 37 once at any time !!!
    • Press the button, and the terminal displays as follows:
      Falling edge is detected on pin 37 !
      Rising edge is detected on pin 37 !
  3. (Optional) Exit the Python3 Virtual Environment.
    deactivate
