Demo Source Code
2.4inch_LCD_demo.py:
#!/usr/bin/python """ Please make sure the 2.4inch LCD Moudle is connected to the correct pins. The following table describes how to connect the 2.4inch LCD Module to the 40-pin header. ------------------------------------------------- __2.4inch LCD Module___Pin Number_____Pin Name VCC 17 3.3 V Power GND 39 GND DIN 19 SPI MOSI CLK 23 SPI SCLK CS 24 SPI CE0 DC 40 GPIO44 RST 11 GPIO42 BL 18 GPIO51 ------------------------------------------------- """ import os import sys import time import logging from PIL import Image sys.path.append("..") import VisionFive.boardtype as board_t from lib import LCD2inch4_lib """ Demo modification ans new function description ------------------------------------------------------------ I. add the clear() function to fill LCD screen with white II. give a hexadecimal value of white III. cycle through multiple pictures --------------------------------------------------------------- """ WHITE = 0xFF def main(): print("-----------lcd demo-------------") # Determining cpu Type: 1 means visionfive1; 2 means visionfive 2 vf_t = board_t.boardtype() if vf_t == 1: SPI_DEVICE = "/dev/spidev0.0" elif vf_t == 2: SPI_DEVICE = "/dev/spidev1.0" else: print("This module can only be run on a VisionFive board!") return 0 """The initialization settings of 2inch and 2.4inch are distinguished""" disp = LCD2inch4_lib.LCD_2inch4(11, 40, SPI_DEVICE) # disp.lcd_init() disp.lcd_init_2inch4() disp.lcd_clear(WHITE) if vf_t == 1: image = Image.open("./visionfive.bmp") elif vf_t == 2: image = Image.open("./visionfive2.png") else: return disp.lcd_ShowImage(image, 0, 0) time.sleep(2) """add the part of displaying pictures circularly""" while True: try: print(time.strftime("%Y-%m-%d %H:%M:%S", time.localtime(time.time()))) """rotate the picture 90 degrees anticlockwise""" """to keep consistent with the display direction of other pictures""" image = Image.open("./LCD_2inch4_parrot.bmp") image = image.transpose(Image.Transpose.ROTATE_90) disp.lcd_ShowImage(image, 0, 0) time.sleep(0.5) image = Image.open("./LCD_2inch.jpg") disp.lcd_ShowImage(image, 0, 0) time.sleep(0.5) if vf_t == 1: image = Image.open("./visionfive.bmp") elif vf_t == 2: image = Image.open("./visionfive2.png") else: return disp.lcd_ShowImage(image, 0, 0) time.sleep(0.5) except KeyboardInterrupt: break print("Exit demo!") if __name__ ==LCD2inch4_lib.py:
import os import sys import time import logging import VisionFive.spi as spi import VisionFive.gpio as gpio import numpy as np from PIL import Image, ImageDraw, ImageFont class LCD_2inch4: width = 240 height = 320 def __init__(self, rst_pin, dc_pin, dev): gpio.setmode(gpio.BOARD) self.rstpin = rst_pin self.dcpin = dc_pin self.spidev = dev spi.getdev(self.spidev) """Reset the maximum clock frequency of communication""" """The display speed of the picture is positively correlated with the clock frequency""" # spi.setmode(500000, 0, 8) spi.setmode(40000000, 0, 8) gpio.setup(self.rstpin, gpio.OUT) gpio.setup(self.dcpin, gpio.OUT) def __del__(self): spi.freedev() """add a short delay for each change of electrical level""" def lcd_reset(self): gpio.output(self.rstpin, gpio.HIGH) time.sleep(0.01) gpio.output(self.rstpin, gpio.LOW) time.sleep(0.01) gpio.output(self.rstpin, gpio.HIGH) time.sleep(0.01) def lcd_spisend(self, data): spi.transfer(data) def lcd_sendcmd(self, cmd): gpio.output(self.dcpin, gpio.LOW) spi.transfer(cmd) def lcd_senddata(self, data): gpio.output(self.dcpin, gpio.HIGH) spi.transfer(data) """write multiple bytes""" def lcd_sendnbytes(self, data): gpio.output(self.dcpin, gpio.HIGH) spi.write(data) """common registers' initialization of 2.4inch LCD module""" def lcd_init_2inch4(self): self.lcd_reset() self.lcd_sendcmd(0x11) # sleep out self.lcd_sendcmd(0xCF) # Ppower Control B self.lcd_senddata(0x00) self.lcd_senddata(0xC1) self.lcd_senddata(0x30) self.lcd_sendcmd(0xED) # Power on sequence control self.lcd_senddata(0x64) self.lcd_senddata(0x03) self.lcd_senddata(0x12) self.lcd_senddata(0x81) self.lcd_sendcmd(0xE8) # Driver Timing Control A self.lcd_senddata(0x85) self.lcd_senddata(0x00) self.lcd_senddata(0x79) self.lcd_sendcmd(0xCB) # Power Control A self.lcd_senddata(0x39) self.lcd_senddata(0x2C) self.lcd_senddata(0x00) self.lcd_senddata(0x34) self.lcd_senddata(0x02) self.lcd_sendcmd(0xF7) # Pump ratio control self.lcd_senddata(0x20) self.lcd_sendcmd(0xEA) # Driver Timing Control B self.lcd_senddata(0x00) self.lcd_senddata(0x00) self.lcd_sendcmd(0xC0) # Power Control 1 self.lcd_senddata(0x1D) # VRH[5:0] self.lcd_sendcmd(0xC1) # Power Control 2 self.lcd_senddata(0x12) # SAP[2:0],BT[3:0] self.lcd_sendcmd(0xC5) # VCOM Control 1 self.lcd_senddata(0x33) self.lcd_senddata(0x3F) self.lcd_sendcmd(0xC7) # VCOM Control 2 self.lcd_senddata(0x92) self.lcd_sendcmd(0x3A) # COLMOD:Pixel Format Set self.lcd_senddata(0x55) self.lcd_sendcmd(0x36) # Memory Access Control self.lcd_senddata(0x08) self.lcd_sendcmd(0xB1) # Frame Rate Control(In Normal Mode/Full Colors) self.lcd_senddata(0x00) self.lcd_senddata(0x12) self.lcd_sendcmd(0xB6) # Display Function Control self.lcd_senddata(0x0A) self.lcd_senddata(0xA2) self.lcd_sendcmd(0x44) # Set_Tear_Scanline self.lcd_senddata(0x02) self.lcd_sendcmd(0xF2) # 3Gamma Function Disable self.lcd_senddata(0x00) self.lcd_sendcmd(0x26) # Gamma curve selected self.lcd_senddata(0x01) self.lcd_sendcmd(0xE0) # Set Gamma self.lcd_senddata(0x0F) self.lcd_senddata(0x22) self.lcd_senddata(0x1C) self.lcd_senddata(0x1B) self.lcd_senddata(0x08) self.lcd_senddata(0x0F) self.lcd_senddata(0x48) self.lcd_senddata(0xB8) self.lcd_senddata(0x34) self.lcd_senddata(0x05) self.lcd_senddata(0x0C) self.lcd_senddata(0x09) self.lcd_senddata(0x0F) self.lcd_senddata(0x07) self.lcd_senddata(0x00) self.lcd_sendcmd(0xE1) # Set Gamma self.lcd_senddata(0x00) self.lcd_senddata(0x23) self.lcd_senddata(0x24) self.lcd_senddata(0x07) self.lcd_senddata(0x10) self.lcd_senddata(0x07) self.lcd_senddata(0x38) self.lcd_senddata(0x47) self.lcd_senddata(0x4B) self.lcd_senddata(0x0A) self.lcd_senddata(0x13) self.lcd_senddata(0x06) self.lcd_senddata(0x30) self.lcd_senddata(0x38) self.lcd_senddata(0x0F) self.lcd_sendcmd(0x29) # Display on def lcd_setPos(self, Xstart, Ystart, Xend, Yend): self.lcd_sendcmd(0x2A) self.lcd_senddata(Xstart >> 8) self.lcd_senddata(Xstart & 0xFF) self.lcd_senddata((Xend - 1) >> 8) self.lcd_senddata((Xend - 1) & 0xFF) self.lcd_sendcmd(0x2B) self.lcd_senddata(Ystart >> 8) self.lcd_senddata(Ystart & 0xFF) self.lcd_senddata((Yend - 1) >> 8) self.lcd_senddata((Yend - 1) & 0xFF) self.lcd_sendcmd(0x2C) def lcd_clear(self, color): """Clear contents of image buffer""" _buffer = [color] * (self.width * self.height * 2) self.lcd_setPos(0, 0, self.width, self.height) gpio.output(self.dcpin, gpio.HIGH) """modify the original single byte write to multi byte write""" # for i in range(0,len(_buffer)): # self.lcd_spisend(_buffer[i]) self.lcd_sendnbytes(_buffer) def lcd_ShowImage(self, Image, Xstart, Ystart): """Set buffer to value of Python Imaging Library image.""" """Write display buffer to physical display""" imwidth, imheight = Image.size if imwidth == self.height and imheight == self.width: img = np.asarray(Image) pix = np.zeros((self.width, self.height, 2), dtype=np.uint8) # RGB888 >> RGB565 pix[..., [0]] = np.add( np.bitwise_and(img[..., [0]], 0xF8), np.right_shift(img[..., [1]], 5) ) pix[..., [1]] = np.add( np.bitwise_and(np.left_shift(img[..., [1]], 3), 0xE0), np.right_shift(img[..., [2]], 3), ) pix = pix.flatten().tolist() self.lcd_sendcmd( 0x36 ) # define read/write scanning direction of frame memory self.lcd_senddata(0x78) self.lcd_setPos(0, 0, self.height, self.width) gpio.output(self.dcpin, gpio.HIGH) """modify the original single byte write to multi byte write""" # for i in range(0,len(pix),1): # self.lcd_spisend(pix[i]) self.lcd_sendnbytes(pix) else: img = np.asarray(Image) pix = np.zeros((imheight, imwidth, 2), dtype=np.uint8) pix[..., [0]] = np.add( np.bitwise_and(img[..., [0]], 0xF8), np.right_shift(img[..., [1]], 5) ) pix[..., [1]] = np.add( np.bitwise_and(np.left_shift(img[..., [1]], 3), 0xE0), np.right_shift(img[..., [2]], 3), ) pix = pix.flatten().tolist() self.lcd_sendcmd(0x36) self.lcd_senddata(0x08) self.lcd_setPos(0, 0, self.width, self.height) gpio.output(self.dcpin, gpio.HIGH) """modify the original single byte write to multi byte write""" # for i in range(0,len(pix)): # self.lcd_spisend(pix[i]) self.lcd_sendnbytes(pix)
