Demo Source Code
RPi_demo_#GPIO_basic#_run_on_VisionFive.py:
#import RPi.GPIO as GPIO # import RPi.GPIO module #******************************************************* #Note: above command must be replaced with command below import VisionFive.gpio as GPIO # import VisionFive.gpio module #******************************************************* from time import sleep # let us have a delay GPIO.setmode(GPIO.BCM) # choose BCM or BOARD GPIO.setup(36, GPIO.OUT) # set GPIO27 as an output try: while True: GPIO.output(36, 1) # set GPIO27 to 1/GPIO.HIGH/True sleep(0.5) # wait half a second GPIO.output(36, 0) # set GPIO27 to 0/GPIO.LOW/False sleep(0.5) # wait half a second except KeyboardInterrupt: # trap a CTRL + C keyboard interrupt GPIO.cleanup() # reset all GPIO ports used by this program
