Running Demo Codes
  1. Locate to the directory where the test code, pud_test.py, exists:
    1. Source into the Python3 Virtual Environment:
      source ./myvenv/bin/activate
    2. Execute the following command to install dependency:
      python3 -m pip install pillow
    3. Execute the following command to get the directory where VisionFive.gpio exists:
      Note:
    4. Execute the following to enter the directory, for example, /home/user/myvenv/lib/python3.11/site-packages as indicated in the previous step output:
    5. Execute the following command to enter the sample-code directory:
      cd ./VisionFive/sample-code/
  2. Under the sample-code directory, execute the following command to execute the demo code:
    sudo python pud_test.py
    sudo python3 pud_test.py
    The terminal displays as follows:
    # python3 pud_test.py
    *----------------------Start testing------------------------------*
    Step 1: set input to direction of GPIO pin 31.
    Step 2: the default input level is HIGH.
    Step 3.1: set PUD_DOWN to input direction of GPIO pin 31.
    Step 3.2: the input level with pull_down enabled is LOW.
    Step 4.1: set PUD_UP to input direction of GPIO pin 31.
    Step 4.2: the input level with pull_up enabled is HIGH.
    *---------------------------end test------------------------------*
  3. (Optional) Exit the Python3 Virtual Environment.
    deactivate
