Interface Description
FFmpeg supports the following libraries (application interfaces):
- libavcodec: encoding/decoding library
- libavfilter: graph-based frame editing library
- libavformat: I/O and muxing/demuxing library
- libavdevice: special devices muxing/demuxing library
- libavutil: common utility library
- libswresample: audio re-sampling, format conversion and mixing
- libpostproc: post processing library
- libswscale: color conversion and scaling library
The StarFive JH7110 SDK supports the standard FFmpeg API library, for more detailed information on each application interface, see FFmpeg Official Documentation.
