Cooling device – CPU device
The following code block provides an example of the cooling device - CPU device.
cpu0: cpu@0 { compatible = "sifive,s7", "riscv"; reg = <0>; d-cache-block-size = <64>; d-cache-sets = <64>; d-cache-size = <8192>; d-tlb-sets = <1>; d-tlb-size = <40>; device_type = "cpu"; i-cache-block-size = <64>; i-cache-sets = <64>; i-cache-size = <16384>; i-tlb-sets = <1>; i-tlb-size = <40>; mmu-type = "riscv,sv39"; next-level-cache = <&cachectrl>; riscv,isa = "rv64imac_zba_zbb"; tlb-split; #cooling-cells = <2>; status = "disabled"; cpu0intctrl: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; interrupt-controller; }; };
The following list provides explanations for the parameters included in the above code
block.
- reg: Register base address .
- status: The work status of the thermal sensor module. To enable the module, set this bit as "okay" or to disable the module, set this bit as "disabled".
