Specifications
VisionFive 2 has the following specifications.
Type Item Description
Processor: StarFive JH7110
StarFive JH7110 with RISC-V quad-core CPU with 2 MB L2 cache and a monitor core, supporting RV64GC ISA, working up to 1.5 GHz
Imagination GPU
IMG BXE-4-32 MC1 with work frequency up to 600 MHz
Memory: 2 GB/4 GB/8 GB LPDDR4 SDRAM, up to 2,800 Mbps
Storage: Onboard TF card slot The VisionFive 2 can boot from a TF card.
Flash The firmware to store U-Boot and bootloader.
Multimedia: Video Output
  • 1 × 2-lane MIPI DSI display port, supporting up to 1080p@30fps
  • 1 × 4-lane MIPI DSI display port, supporting up to 2K@30fps in both single display and dual display modes.
  • 1 × HDMI 2.0, supporting up to 4K@30fps or 2K@60fps
Note: Only one MIPI DSI port can be used for display at a time.
Camera 1 × 2-lane MIPI CSI camera port, supporting up to 1080p@30fps
Encoder/Decoder
  • Video decoder supports up to 4K@60fps and multi-stream for H264/H265;
  • Video encoder supports up to 1080p@30fps and multi-stream for H265;
  • JPEG encoder/decoder
Audio 4-pole stereo audio jack
Connectivity: Ethernet 2 × RJ45 Gigabit Ethernet ports
USB Host 4 × USB 3.0 ports (multiplexed with a PCIe 2.0 1x lane).
USB Device 1 × USB device port (by reusing the USB-C port)
M.2 Connector M.2 M-Key
eMMC Socket For eMMC modules as OS and data storage
2-Pin Fan Header -
Power: USB-C port 5 V DC via USB-C with PD, up to 30 W (minimum 3 A)
GPIO Power In 5 V DC via GPIO header (minimum 3 A)
PoE (Power over Ethernet) PoE function is enabled and requires separate PoE HAT
GPIO: 40-Pin GPIO Header 1 × 40-pin GPIO header, supporting various interface options:
  • 3.3 V (on 2 pins)
  • 5 V (on 2 pins)
  • Ground (on 8 pins)
  • GPIO
  • CAN bus
  • DMIC
  • I2C
  • I2S
  • PWM
  • SPI
  • UART
  • and so on
Boot Mode: Boot mode setting pins You can choose one of the following boot modes:
  • 1-bit QSPI Nor Flash
  • SDIO3.0
  • eMMC
  • UART
Button: Reset button To reset VisionFive 2, press and hold the Reset button for more than 3 seconds to ensure the reset is successful.
Dimensions:
100 × 74 mm
Compliance: RoHS, FCC, CE
Environment: Recommended operating temperature 0-50 ℃
Other: Debug function UART TX and UART RX are available through the 40-pin GPIO header.
