GMAC Source Code Structure
The source code of GMAC is located in the following
path:
Drivers/net/ethernet/stmicro/stmmac
The following code block provides an example of the GMAC source code.
1 Drivers/net/ethernet/stmicro/stmmac 2 3├── stmmac.h 4 ├── dwmac-starfive-plat.c 5 ├── stmmac_main.c
| File | Explanation |
| stmmac.h | GMAC driver header file of the DWMAC platform. In this file, some macros, data structures and internal interfaces are defined. |
| dwmac-starfive-plat.c | GMAC driver specific configuration options of the StarFive DWMAC platform |
| stmmac_main.c | GMAC driver public interface on the DWMAC platform |
