Specifications
VisionFive 2 has the following specifications.
| Type | Item | Description |
| Processor | StarFive JH-7110 |
StarFive JH-7110 with RISC-V quad-core CPU with 2 MB L2 cache and a monitor core, supporting RV64GC ISA, working up to 1.5 GHz |
Imagination GPU |
IMG BXE-4-32 MC1 with work frequency up to 600 MHz |
| Memory | 2 GB/4 GB/8 GB | LPDDR4 SDRAM, up to 2,800 Mbps |
| Storage | Onboard TF card slot | VisionFive 2can boot from a TF card. |
| Flash | The firmware to store U-Boot and BootLoader. | |
| Multimedia | Video Output |
Note: Only one MIPI DSI port can be used for display at a time.
| Camera | 1 × 2-lane MIPI CSI camera port, supporting up to 1080p@30fps | |
| Encoder/Decoder |
| Audio | 4-pole stereo audio jack | |
| Connectivity | Ethernet | 2 × RJ45 Gigabit Ethernet ports |
| USB Host | 4 × USB 3.0 ports (multiplexed with a PCIe 2.0 1x lane). | |
| USB Device | 1 × USB device port (by reusing the USB-C port) | |
| M.2 Connector | M.2 M-Key | |
| eMMC Socket | For eMMC module as OS and data storage. | |
| 2-Pin Fan Header | - | |
| Power | USB-C port | 9 V to 12 V DC via USB-C with PD, up to 30 W (minimum 2 A) |
| GPIO Power In | 5 V DC via GPIO header (minimum 3 A) | |
| PoE (Power over Ethernet) | Power function is enabled and requires separate PoE HAT | |
| GPIO | 40-Pin GPIO Header | 1 × 40-pin GPIO header, supporting various interface options:
| Boot Mode | Boot mode setting pins | You can choose one of the following boot modes:
| Button | Reset button | To reset VisionFive 2, press and hold the Reset button for more than 3 seconds to ensure the reset is successful. |
| Dimensions |
100 × 74 mm |
| Compliance | RoHS, FCC, CE |
| Environment | Recommended operating temperature | 0-50 ℃ |
| Other | Debug function | UART TX and UART RX are available through the 40-pin GPIO header. |
