Required Hardware
Make sure that the following hardware are prepared for the operation described in this manual:
VisionFive 2
Micro SD card (32 GB or more)
USB card reader for your host PC
PC with Linux/Windows/Mac OS
Power adapter
USB Type-C Cable
For desktop environment usage:
- Keyboard and mouse
- Monitor or TV
- HDMI cable
Additionally, here are some optional components which you may also need:
- Ethernet LAN cable or a compatible WiFi dongle (ESWIN6600U or AIC8800 module is enabled by default)
- USB to UART Serial converter moduleTip: This is used for system recovery via UART boot mode.
Note: In this guide, Ubuntu 18.04 LTS is installed on the host PC.
