Running Demo Codes
This example will demonstrate defect detection based on image recognition. The principle is to locate and highlight the positions of defects on the surface of a product by identifying connected regions that are too large.
The running method is as the following:
Step:
To run C++ application:
Perform the following step under the user directory on VisionFive 2 Debian to run the C++ demo:
example_3rd_imgproc_defect_detection
- The HDMI monitor will display the original image of the product, as well as the processed result image that is marked with the detected defect areas;
- The terminal will display the serial number and area of the connected region to which the defect area belongs.
