Device Tree Configuration
In the DTSI file, the system provides general configuration information for DMA
controller, see the following code block for an example.
Note: You
are not recommended to change the following configuration. If you need to change,
make sure you contact your system maintenance engineer in advance.
dma: dma-controller@16050000 { compatible = "starfive,jh7110-dma", "snps,axi-dma-1.01a"; reg = <0x0 0x16050000 0x0 0x10000>; clocks = <&clkgen JH7110_DMA1P_CLK_AXI>, <&clkgen JH7110_DMA1P_CLK_AHB>; clock-names = "core-clk", "cfgr-clk"; resets = <&rstgen RSTN_U0_DW_DMA1P_AXI>, <&rstgen RSTN_U0_DW_DMA1P_AHB>; reset-names = "rst-axi", "rst-ahb"; interrupts = <73>; dma-cells = <2>; dma-channels = <4>; snps,dma-masters = <1>; snps,data-width = <3>; snps,num-hs-if = <56>; snps,block-size = <65536 65536 65536 65536>; snps,priority = <0 1 2 3>; snps,axi-max-burst-len = <16>; status = "disabled"; };
The following list provides explanations for the parameters included in the above code
block.
- reg: Register base address "0x16050000" and range "0x10000".
- clocks: The clocks used by the DMA module.
- clock-names: The names of the above clocks.
- resets: The reset signals used by the DMA module.
- reset-names: The names of the above reset signals.
- interrupts: Hardware interrupt ID.
- dma-cells: The field is used to configure DMA cells via DTS configuration.
- dma-channels: The supported DMA channels.
- dma-masters: The supported AXI master interfaces.
- data-width: The field is used to configure data bus width (Unit: Byte). The default value is 3.
- num-hs-if: The total count of hardware handshakes, maximum 56 handshakes.
- priority: The priorities of the 4 channels mentioned in the dma-channels field.
- axi-max-burst-len: The maximum data length allowed in one single transmission.
- status: The work status of the DMA module. To enable the module, set this bit as "okay" or to disable the module, set this bit as "disabled".
