Kernel Menu Configuration
Follow the steps below to enable the kernel configuration for DMA.
    make linux-menuconfig
    Figure 1. Device Drivers
  3. Select the DMA Engine support option and enter the next level.
    Figure 2. DMA Engine Support
  4. In the DMA Engine support menu, select the DesignWare DMA Support and the DesignWare DMA Support for StarFive SoC options.
    Figure 3. DesignWare DMA Support
  5. Save your change before you exit the kernel configuration dialog.
