Kernel Menu Configuration
Follow the steps below to enable the kernel configuration for HDMI.
    make linux-menuconfig
    Figure 1. Device Drivers
  3. Enter the Graphics support menu.
    Figure 2. Graphics Support
  4. In the Graphics support menu, select the DRM Support option to enable video output.
    Figure 3. DRM Support
  5. In the Graphics support menu, select the HDMI2.0 option.
    Figure 4. HDMI2.0
  6. Save your change before you exit the kernel configuration dialog.
