Module and Control Info
The following code block shows the data structure for the module control and information structure.
typedef struct _ST_MOD_CTL_INFO {
    STF_U8 u8Id;
    STF_U32 u32Offset;
    STF_U16 u16ParamSize;
} ST_MOD_CTL_INFO, *PST_MOD_CTL_INFO;
Table 1. Module and Control Info Field Description
Field Description
u8Id Module/Control ID
u32Offset location
u16ParamSize Parameters size
