RAW dump table
The following code block shows the data structure for the RAW dump table structure.
typedef struct _ST_RAW_DUMP_TBL {
    STF_U8 u8Idx;
    STF_U8 u8TblCnt;
    STF_U8 u8CaptureCount;
    CI_BUFFTYPE enBufferType;
    CI_MEM_PARAM stDumpMem[CONTIGUOUS_CAPTURE_BUF_MAX];
} ST_RAW_DUMP_TBL, *PST_RAW_DUMP_TBL;
Table 1. RAW Dump Table Field Description
Field Description
u8Idx Indicate current use buffer
u8TblCnt Indicate total allocate buffer count
u8CaptureCount Indicate how many images to capture
enBufferType Indicate those buffers will be used for which image buffer
stDumpMem RAW dump table
