Device Tree configuration
A DTS/DTSI file is used to store all the device tree configuration.
The device tree of MIPI LCD is stored in the following path:
linux-5.10/arch/riscv/boot/dts/starfive/
The following code block shows the DTS file structure for MIPI LCD.
linux-5.15.0
└-- arch
└-- | -- riscv
| -- | -- | -- boot
| -- | -- | -- | -- dts
| -- | -- | -- | -- | -- starfive
| -- | -- | -- | -- | -- | -- jh7110-common.dtsi
| -- | -- | -- | -- | -- | -- jh7110.dtsi
MIPI DSI
In the file jh7110.dtsi, you can find the device tree configuration of MIPI DSI as the following code block:
linux/arch/riscv/boot/dts/starfive/jh7110.dtsi:
		 mipi_dsi: mipi@295d0000 {
			compatible = "starfive,jh7110-mipi_dsi","cdns,dsi";
			reg = <0x0 0x295d0000 0x0 0x10000>;
			interrupts = <98>;
			reg-names = "dsi";
			clocks = <&clkvout JH7110_U0_CDNS_DSITX_CLK_SYS>,
				 <&clkvout JH7110_U0_CDNS_DSITX_CLK_APB>,
				 <&clkvout JH7110_U0_CDNS_DSITX_CLK_TXESC>,
				 <&clkvout JH7110_U0_CDNS_DSITX_CLK_DPI>;
			clock-names = "sys", "apb", "txesc", "dpi";
			resets = <&rstgen RSTN_U0_CDNS_DSITX_DPI>,
				 <&rstgen RSTN_U0_CDNS_DSITX_APB>,
				 <&rstgen RSTN_U0_CDNS_DSITX_RXESC>,
				 <&rstgen RSTN_U0_CDNS_DSITX_SYS>,
				 <&rstgen RSTN_U0_CDNS_DSITX_TXBYTEHS>,
				 <&rstgen RSTN_U0_CDNS_DSITX_TXESC>;
			reset-names = "dsi_dpi", "dsi_apb", "dsi_rxesc",
					"dsi_sys", "dsi_txbytehs", "dsi_txesc";
			phys = <&mipi_dphy>;
                       phy-names = "dphy";
			status = "disabled";
			port {
				dsi_out_port: endpoint@0 {
					remote-endpoint = <&panel_dsi_port>;
				dsi_in_port: endpoint@1 {
					remote-endpoint = <&mipi_out>;
			mipi_panel: panel@0 {
				/*compatible = "";*/
				status = "okay";
linux/arch/riscv/boot/dts/starfive/jh7110-common.dtsi:
&mipi_dsi {
	status = "okay";
The following list provides explanations for the parameters included in the above code block.
  • compatible: Compatibility information, used to associate the driver and its target device.
  • reg: Register base address "0x295d0000" and range "0x10000".
  • interrupts: Hardware interrupt ID.
  • reg-name: The name of the above register.
  • clocks: The clocks used by the LCD module.
  • clock-names: The names of the above clocks.
  • resets: The reset signals used by the LCD module.
  • reset-names: The names of the above reset signals.
  • phys: The phys used by the LCD module.
  • phy-names: The name of the phys.
  • status: The work status of the LCD module. To enable the module, set this bit as "okay" or to disable the module, set this bit as "disabled".
  • port: The port(s) used by the LCD driver.
MIPI DPHY
In the file jh7110.dtsi, you can find the device tree configuration of MIPI DPHY as the following code block:
linux/arch/riscv/boot/dts/starfive/jh7110.dts:
		mipi_dphy: mipi-dphy@295e0000{
			compatible = "starfive,jh7110-mipi-dphy-tx","m31,mipi-dphy-tx";
			reg = <0x0 0x295e0000 0x0 0x10000>;
			clocks = <&clkvout JH7110_U0_MIPITX_DPHY_CLK_TXESC>;
			clock-names = "dphy_txesc";
			resets = <&rstgen RSTN_U0_MIPITX_DPHY_SYS>,
				 <&rstgen RSTN_U0_MIPITX_DPHY_TXBYTEHS>;
			reset-names = "dphy_sys", "dphy_txbytehs";
			#phy-cells = <0>;
linux/arch/riscv/boot/dts/starfive/jh7110-common.dts:
&mipi_dphy {
	status = "okay";
  • reg: Register base address "0x295e0000" and range "0x10000".
I2C2
In the file jh7110-common.dtsi, in order to configure LCD DTS port, the seeed_panel dts port should be added into i2c2. You can find the device tree configuration of i2c2 as the following code block:
&i2c2 {
	clock-frequency = <100000>;
	i2c-sda-hold-time-ns = <300>;
	i2c-sda-falling-time-ns = <510>;
	i2c-scl-falling-time-ns = <510>;
	auto_calc_scl_lhcnt;
	pinctrl-names = "default";
	pinctrl-0 = <&i2c2_pins>;
	status = "okay";
	seeed_plane_i2c@45 {
		compatible = "seeed_panel";
		reg = <0x45>;
		port {
			panel_dsi_port: endpoint {
				remote-endpoint = <&dsi_out_port>;
In the above code block, the parameters of pinctrl-names and pinctrl-0 are used to configure the i2c2 pin configuration settings.
