Test Example
For LCD Output
The following command shows an example for testing the LCD output.
modetest -M starfive -D 0 -a -s 118@35:800x480 -P 74@35:800x480@RG16 -Ftiles
The following list provides explanations for the parameters in the above example command.
  • 118@35:800x480 - <Connector ID>@<CRTC ID>: <Resolution>
  • 74@35:800x480@RG16 - <Plane ID>@<CRTC ID>: <Resolution>@<Format>
Output Result
The following photo shows the output generated from the above example command.
Figure 1. Test Example
