Use DSI Tool
  1. Install Git and open the dsi_tool_v2.0 folder.
  2. Right-click under the dsi_tool_v2.0 folder to show options.
  3. Choose Git Bash Here option, and open it.
    Figure 1. Git Bash Here
  4. Run the following to generate output.txt:
    ./run.sh
    Figure 2. ./run.sh
    Note: If the screen manufacturer does not provide the ratio of dsi_hblank_ratio, you can use the default ratio in the following two methods:
    • Set the value of r_hsa, r_hbp, or r_hfp in the input.md file to 0.
    • Generally use r_hsa (2), r_ hbp(2), r_ hfp(2).
