Kernel Menu Configuration
Follow the steps below to enable the kernel configuration for PWM.
    make linux-menuconfig
    Figure 1. Device Drivers
  3. Enter the PWM support menu.
    Figure 2. PWM Support
  4. Select the StarFive PWM PTC Support option.
    Figure 3. StarFive PWM PTC Support
  5. Save your change before you exit the kernel configuration dialog.
