Device Tree Configuration
The PWM device tree source code is stored under the ptc node in the file of jh7110.dts.
The following code block provides more
detail.
ptc: pwm@120d0000 { compatible = "starfive,pwm"; reg = <0x0 0x120d0000 0x0 0x10000>; reg-names = "control"; clocks = <&clkgen JH7110_PWM_CLK_APB>; resets = <&rstgen RSTN_U0_PWM_8CH_APB>; starfive,approx-freq = <2000000>; #pwm-cells=<3>; starfive,npwm = <8>; status = "disabled"; };
The following list provides more descriptions for the configuration bits.
- reg: Register base address "0x120d0000" and range "0x10000".
- reg-names: The names of the registers used by the PWM module.
- clocks: The clocks used by the PWM module.
- resets: The reset signals used by the PWM module.
- interrupts: Hardware interrupt ID.
- approx-frequency: Edit this bit to configure the approximate frequency of PWM.
- status: The work status of the PWM module. To enable the module, set this bit as "okay" or to disable the module, set this bit as "disabled".
