Function Introduction
The JH7110 SoC Platform supports the following features and specifications on SPI.
  • Support 7 SPI interfaces.
  • Support serial-master mode and serial-slave mode. Use software configuration to switch between the two modes.
  • Provide separate data bits for input and output.
  • Provide configurable FIFO with size up to 8-bit × 16-bit for both TX and RX channels.
  • Support DMA access for TX and RX FIFO.
