DEBUG_DEVRES
You can configure the DEBUG_DEVRES option to manage the debug functions for device resources. If this option is enabled, the system will print all the DEVRES debug messages. Also, you can use the dm devres command to dump the list of device resources for each devices.
Make sure to select this option if you are having a problem with DEVRES or want to debug the resource management for a managed device.
