This document mainly provides the users with the features and technical specifications for StarFive VisionFive 2 Single Board Computer (SBC).
Table 1. Revision History
Version Released Revision
1.3.1 2023/07/18 Updated the description in Overview.
1.3 2022/12/08
Updated the power requirement via USB-C port.
Added a note on using spacers in Physical Specifications.
Updated the dimensions.
1.2 2022/10/20
  • Revised the display of MIPI CSI.
  • Updated the USB port description.
  • Added 1 × USB device port.
  • Updated the GPU description.
  • Updated the Reset button description.
1.1 2022/09/08
  • Updated the mechanical drawings.
  • Updated the description about Reset button.
1.0 2022/08/23 The first release.
