Specifications
VisionFive 2 has the following specifications.
Type | Item | Description |
Processor | StarFive JH7110 |
StarFive JH7110 with RISC-V quad-core CPU with 2 MB L2 cache and a monitor core, supporting RV64GC ISA, working up to 1.5 GHz |
Imagination GPU |
IMG BXE-4-32 MC1 with work frequency up to 600 MHz |
Memory | 2 GB/4 GB/8 GB | LPDDR4 SDRAM, up to 2,800 Mbps |
Storage | Onboard TF card slot | VisionFive 2can boot from a TF card. |
Flash | The firmware to store U-Boot and BootLoader. | |
Multimedia | Video Output |
Note: Only one MIPI DSI port can be used for display at a time.
Camera | 1 × 2-lane MIPI CSI camera port, supporting up to 1080p@30fps | |
Encoder/Decoder |
Audio | 4-pole stereo audio jack | |
Connectivity | Ethernet | 2 × RJ45 Gigabit Ethernet ports |
USB Host | 4 × USB 3.0 ports (multiplexed with a PCIe 2.0 1x lane). | |
USB Device | 1 × USB device port (by reusing the USB-C port) | |
M.2 Connector | M.2 M-Key | |
eMMC Socket | For eMMC module as OS and data storage. | |
2-Pin Fan Header | - | |
Power | USB-C port | 5 V DC via USB-C with PD, up to 30 W (minimum 3 A) |
GPIO Power In | 5 V DC via GPIO heade (minimum 3 A) | |
PoE (Power over Ethernet) | Power function is enabled and requires separate PoE HAT | |
GPIO | 40-Pin GPIO Header | 1 × 40-pin GPIO header, supporting various interface options:
Boot Mode | Boot mode setting pins | You can choose one of the following boot modes:
Button | Reset button | To reset VisionFive 2, press and hold the Reset button for more than 3 seconds to ensure the reset is successful. |
Dimensions |
100 × 74 mm |
Compliance | RoHS, FCC, CE |
Environment | Recommended operating temperature | 0-50 ℃ |
Other | Debug function | UART TX and UART RX are available through the 40-pin GPIO header. |
