Hardware Specifications
The following table lists the hardware specifications of the JH-7110 DevKit.
| Type | Item | Description |
| Memory | DDR4 | 2 × DDR4, max capacity is 4 GB |
| eMMC | 32 GB, max capacity is 128 GB | |
| QSPI Flash | The max capacity is 16 MB | |
| Interface | Display |
| RGB Adapter Board | LVDS/VGA/ RGB | |
| TF Card | 1 | |
| Camera | 1 × MIPI-CSI, supporting up to 1080p@30fps CMOS RGB image sensor | |
| PCIe | support 2 PCIe × 4 lane connector, JH-7110 SoC only support 1-lane | |
| USB |
| URAT |
| CAN | 1 | |
| GPIO | Support 64 GPIOs: sysfs(/sys/class/gpio/*) and chardev(/dev/gpiochip/*) interface | |
| M.2 |
| Audio |
| Ethernet | 2 × 10/100/1000M self-negotiation | |
| JTAG | - | |
| WiFi | WiFi/BLE |
| Power | Key |
| Awaken |
| Thermal | - | JH-7110 DevKit can pass various pressure tests without fan. |
| Boot Mode | Recommended Boot Mode | QSPI + eMMC |
| QSPI + TF card | ||
| Size | Core board | 54 × 54 mm |
| Bottom board | 170 × 170 mm |
