Software Specifications
The following table lists the software specifications of the JH-7110 DevKit.
| Type | Item | Description |
| OS | Debian | The on-board operating system of JH-7110 DevKit. |
| Buildroot | Support Buildroot: 2021.11. | |
| Kernel | Version | Support Linux Kernel 5.15.0 & 6.1.31. |
| Power Management Subsystem | The subsystem includes following functions:
| Drivers | WIFI | It can be controlled by GPIO. |
| Bluetooth | - | |
| RTC | External RTC Chip (AT8563) with I2C powered by CR2032 battery. | |
| eDP | Support MIPI to eDP display (BOE eDP 14inch 1080p@60fps LCD). | |
| MIPI DSI | Support 4.3/5/7inch 800*480 MIPI 2-lane touch screen LCD (WaveShare). | |
| LVDS | 10.1 inches. | |
| Audio (External expansion chip) |
| Camera | 2-lane CSI MIPI camera IMX219 with 1080p@30fps. | |
| Watchdog | Supports Watchdog reset, 32-bit down counter. | |
| Timer | 4 sets of timers. | |
| CAN | 1 set of CAN2.0B or CANFD, default is CANFD.
| Temp Sensor | Internal temp sensor, 12-bit resolution. | |
| Tool | Flash tool | Flash through USB. |
| Debug tool | Debug through ISP. |
