Connect JH-7110 DevKit to Network
This section provides steps to connect JH-7110 DevKit to network and enter U-Boot terminal.
Connect the jumper wires between the USB-to-Serial converter and the UART0 Debug pins of JH-7110 DevKit debug header. The following figure is an example:
Figure 1. Connecting to the UART0 Debug Pins of JH-7110 DevKit Tip: You can also use the USB-to-Serial converter of Type-C port to connect Type-C debug port directly. - Configure the serial port baud rate settings to 115200 bps.
- Connect JH-7110 DevKit to the network cable and power cord.
- Turn on JH-7110 DevKit and you
will see the start-up information as
follows:
U-Boot SPL 2021.10 (Apr 27 2023 - 01:11:58 +0800) DDR version: 5129c280. Trying to boot from SPI OpenSBI v1.2 ____ _____ ____ _____ / __ \ / ____| _ \_ _| | | | |_ __ ___ _ __ | (___ | |_) || | | | | | '_ \ / _ \ '_ \ \___ \| _ < | | | |__| | |_) | __/ | | |____) | |_) || |_ \____/| .__/ \___|_| |_|_____/|___/_____| | | |_| Platform Name : StarFive JH7110 DevKits Platform Features : medeleg Platform HART Count : 5 Platform IPI Device : aclint-mswi Platform Timer Device : aclint-mtimer @ 4000000Hz Platform Console Device : uart8250 Platform HSM Device : --- Platform PMU Device : --- Platform Reboot Device : pm-reset Platform Shutdown Device : pm-reset Platform Suspend Device : --- Firmware Base : 0x40000000 Firmware Size : 392 KB Firmware RW Offset : 0x40000 Runtime SBI Version : 1.0 Domain0 Name : root Domain0 Boot HART : 1 Domain0 HARTs : 0*,1*,2*,3*,4* Domain0 Region00 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: () Domain0 Region01 : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: () Domain0 Region02 : 0x0000000040040000-0x000000004007ffff M: (R,W) S/U: () Domain0 Region03 : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X) Domain0 Next Address : 0x0000000040200000 Domain0 Next Arg1 : 0x0000000042200000 Domain0 Next Mode : S-mode Domain0 SysReset : yes Domain0 SysSuspend : yes Boot HART ID : 1 Boot HART Domain : root Boot HART Priv Version : v1.11 Boot HART Base ISA : rv64imafdcbx Boot HART ISA Extensions : none Boot HART PMP Count : 8 Boot HART PMP Granularity : 4096 Boot HART PMP Address Bits: 34 Boot HART MHPM Count : 2 Boot HART MIDELEG : 0x0000000000000222 Boot HART MEDELEG : 0x000000000000b109 U-Boot 2021.10 (Apr 27 2023 - 01:11:58 +0800), Build: jenkins-Devkits_515_Branch_Customer_Build-3 CPU: rv64imacu Model: StarFive JH7110 DevKits DRAM: 4 GiB MMC: sdio0@16010000: 0, sdio1@16020000: 1 Loading Environment from SPIFlash... SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB OK In: serial Out: serial Err: serial Model: StarFive JH7110 DevKits Net: eth0: ethernet@16030000, eth1: ethernet@16040000 Hit any key to stop autoboot: 0 StarFive #
- Press any key to stop and enter the U-Boot terminal.
