Device Tree Configuration
Due to the RTC device being mounted on the I2C bus, the RTC
device tree node should be added to the I2C device node. The I2C device address of
AT8563 RTC is 0×51. The following is the RTC device tree source
code:
rtc@51 { compatible = "nxp,pcf8563"; reg = <0x51>; };
The following list provides explanations for the parameters
included in the above code block.
- reg: The I2C device address of RTC is "0×51".
